Match-Drilled #30 the hole in the upper flange of the CB-1002G Clip into the CB-1003A Cylinder 2 Baffle. Trimmed the forward and outboard edges of the CB-1002A and CB-710A Forward Air Ramps to allow the CB-1009A Cylinder 2 Baffle to angle inboard and to provide clearance with the cowl. Made a vertical bend in the cylinder 2 baffle Adjusted the main ramp angle bend until the CB-1002A Forward Air Ramp matched up to the inboard cowl inlet tangent point. Made a ramp crossing bend from the inboard cowl inlet tangent point to the outboard end of the main ramp angle bend. Marked the outbd edge of the CB-1002A Forward Air Ramp on the CB-1009A Cylinder 2 Baffle. Trimmed the upper edge of CB-702E Fwd Left Support Plate even with the lower face of the CB-1002A Fwd Left Air Ramp. Fastened the support plate to the engine.
