Page 8-63 Bolted the Rudder Pedal Assembly to the forward cockpit floor and Firewall Assembly (See “Isometric View”, DWG 81). Attached an AN43B eyebolt to the fwd end of both F-852B Fwd Rudder Cable Assemblies (See “Isometric View”, DWG 81). Attached the eyebolts on the F-852B Forward Rudder Cables to the Firewall Assembly using the 1/4 holes previously match-drilled from the F-801L Backing Plates (See DWG 60 & 81). Installed brake lines.
