I decided to start with some small parts first. I built the front & rear rudder pedals, only putting brakes in front. I also made the links that the cables will attach to. I did not have the right size tubing for the bushings that the bolts go through to attach the cable link and I am out of welding rod so this is on hold till I come in for my next 7 days off!
Front rudder pedals with brake pedals
I drilled some scrap aluminum I had around to hold the brake cylinder mounts in place to tack them
