The holes in all four fuel tanks for fuel sender installation were fly cut (59mm). The holes in the top skin for the fuel filler necks and sender inspection panels. The holes for the tank sumps were cut in the bottom skin. The holes for the fuel line fittings were cut in the rear channel. The holes for the fuel lines from both inboard and outboard tanks were cut in the rear ribs.
