Brief Description: Assembled nose ribs and rear ribs to main spar
Four nose ribs in each main wing have brackets to support the slats. A gusset made from L-angle stock is part of the assembly. Eight gussets were made. The three pieces per rib were assembled, drilled, deburred, applied with ZP, reassembled, and riveted.
The rear ribs (8V1-2A and 8V1=2B) were fitted to the main left spar.
