Brief Description: Installed Right Aileron Torque Tubes/Bellcranks
Bellcrank AN3 bolts torqued to 35 inch pounds (25"lbs +10"lbs for nylock torque). AN-4 bolts were torqued to 78 inch pounds (70"lbs + 8"lbs for nylock torque). Cross check torque seal applied to all hardware.
Bellcrank AN3-6A bolts 25"lbs +10"lbs for nylock torque
