Brief Description: 1/4" Fuselage Former Installation
Per the instructions, I measured and cut the 1/4" formers from the stock. The stock came in 2x ~144" pieces and 1x ~48" piece. I cut the first lower side former from one of the long pieces and realized after that I probably need to be a bit stategic in which piece of stock I use for each former. I ended up using the following cut schedule with the stock pieces:
- 144" Stock piece: both fuselage bottom outside formers (70" each) - 144" Stock piece: the fuselage bottom center former (96") and one fuselage side lower former (42") - 48" Stock piece: the other fuselage side lower former (42")
