Brent Connelly - N913BC
RV-12
48 - Exhaust System
6-1-2013
Cut tailpipe
Purchased pipe cutter to trim the tailpipe. Needed to removed the muffler from engine in order to access the tailpipe with the cutter. Cut pipe to 4" from lower cowl and re-installed muffler assembly.
RV-12 Home
1337
06 - Vert. Stabil
07 - Rudder
08 - Anti-Servo Tab
09 - Stabilator
10 - Tailcone
11 - Emp Attachment
12 - Emp Fairings
13 - Spar Assembly
13 Spar Assembly
14 - Rear spar, tub
15 - Wing Ribs
16 - Stall Warning
17 - Wing Skins
18 - Flaperon
20 - Ctr Section Bul
21 - Mid Fuse Ribs &
22 - Fwd Lower Fuse
23 - Side Skins
24 - Rollover Struct
25 - Tailcone Attach
26 - Seat Backs
27 - Rudder Petals &
28 - Fuel System
29 - Fwd Up. Fuselag
30 - Wing Attachment
31A - Wing Electrica
31B - Fuselage Wire
32 - Flight Controls
33 - Miscellanea
34 Canopy Install
35 Landing Gr. Engin
36 - Gear/Leg Fairin
37 - Fuel Tank
38 - Cowling
40 - Lighting
41 - Interior Panel
42C - Skyview D1000
42D - Skyview Update
42F - ACK E-04 ELT
44A - Autopilot Serv
45A - FW FWD Wiring
46 - Engine Installa
47 - Spinner Propell
48 - Exhaust System
49 - Cooling System
50 - Engine Controls
51A - Placards
52 - Towbar
53 - Skyview ADS-B
54 - Stiffener Retro
Finishing
Hanger
Int.Options/Paint
Production Acceptanc
SB 12-11-09
SB 13-04-05
SB 13-08-08
Workshop
