Completed soldering the four wires to the ELT jack in the fuselage. Not at all an easy job and my soldering skills are awful. However I think it was done correctly and per the plans I added some RTV sealant to the jack interior that should hold the wires together better. Attached the ELT antenna as well and bent it so that it doesn't interfere with the back window.
Connected all the varous other wires to the ELT and organized them as best I could before attaching two long zip ties. Did a test per the plan to see if the battery works, which it does. But will have to wait until the rest of the aircraft electrical system is working before I can fully test the GPS ect...
