Brief Description: Re-attached main gear legs to center fuselage
Removed the wheels from the gear legs and installed the four brackets that are needed for the main wheel fairings. One of the brake pad attach bolts is very tight to the interior fairing bracket. Needed to file the bracket to be able to rotate the bolt. Then attached both the left and right gear legs to the fuselage and worked in making sure all the bolts and nuts were correctly set and tightened.
Finished up to step 46 in SB plans but didn't final torque the various bolts even tough the gear legs were reattached to the fuselage.
