Brent Connelly - N913BC
Date:  12-18-2012
Number of Hours:  3.00
Manual Reference:  36-10
Brief Description:  Additional work on nose wheel fairing
Added drill template to the forward wheel fairing brackets and drilled the #19 holes. Then added the Doubler Plates and match drilled them as well. Deburred and countersunk one side of each. Dimpled the brackets but had difficulty with the most forward hole given its location so close to one of the nutplates. After grinding down one of the dimple dies, was able to complete it. Will rivet everything next.
