Brief Description: Added H/W to nose fork and fitted nose leg fairing
Added the hardward to the nose fork after enlarging the attach holes to 5/16". Trimmed the gear leg fairing then added it to the gear leg for more fitting. Added epoxy/flox mixture to the two screw hole areas. Will let set up before doing more work on the fairing.
