Brief Description: Finished priming and clecoed first skin to left wi
Finished priming the first two large skins for left wing. Tried to put a slight bend on the edges that will be riveted on top of other skins - not thrilled with my technique but should be fine in the end.
Spencer helped place both skins in the skeleton and also helped cleco the inboard skin onto the ribs. Perfect fit. Will rivet next time I'm in the shop. Also primed and deburred the skin doubler tonight.
