Brief Description: Began preping the 1279 L/R skins for tailcone
Got started on removing plastic, deburing, and priming the next two side skins. Will not be able to finally rivet them to tailcone until I finish the static system, but I wanted to get them ready to go.
Primed the outside areas that need to be primed (where they lie under the topskin for riveting. Will prime the entire inside surface next.
Spencer helped debure the drill holes on one of the skins.
