Brief Description: Trimmed, sanded and fitting of nose wheel fairing
Worked on the nose wheel fairing sections today. Cut and sanded up to the trim line. Bent splice plate to fit forward section and countersunk the #40 attach holes. Then began fitting and sanding both sections to get a good fit. Tedious as the clecos are installed from the inside. After a couple of more rounds of adjustments, fit should be satisfactory.
