Brent Connelly - N913BC
Date:  8-4-2012
Number of Hours:  6.00
Manual Reference:  35-03
Brief Description:  Installed both main gear legs to fuselage
Long day but managed to install both main gear legs to the fuselage. Torqued all the bolts and only have one that I am not happy with and will likely replace as I believe the nut is stripped. Otherwise the install is complete. Very small openings and area to work so it took a long time to properly install all the bolts. Needed to buy an angled socket wrench at Home Depot to complete the install.
Channel with attach plates for gear legs
Leaf gear leg
Leaf gear leg
