Brief Description: Oil Tank Braces and Upper Fuse Skin
Assembled the Ail Tank Braces to the upper firewall. Didn't have enough CS4-4 rivets (flush pull rivets) to completed the install so I will have to order more of those. Also forgot to rivet a line of rivets against the firewall and only noticed this later. Will get back to that.
Screwed the upper fuse skin to the fuselage and it fit very well. Certainly makes the front end of the aircraft more prominant. Began working on the attach strips and dimpled both strips and the nutplates.
Oil Tank Brace
Upper Fuse Skin screwed temporarily to the fuselage
