Brent Connelly - N913BC
Date:  5-9-2011
Number of Hours:  2.50
Manual Reference:  07-01 to 07-02
Brief Description:  Began work on rudder
Began working on rudder tonight. After finding all the parts (took almost twenty minutes as I had not kept all the small items in the same place) I started removing plastic coating and separating the brackets. No challenges so far as I am getting better working with the aluminum parts.
Had to take a conf call for work but for some of it I was able to work on cleaning and deburring some parts. I'm ready to pair up the spar to the vertical stabilizer tomorrow and adjust the lower hinge per the manual. Not exactly sure how to do this so I'll need to do some reading before digging into it.
Lower rudder horn
Lower rudder horn
Temporary bracket fitting
Prepared the ribs for next steps
