I finished drilling and installing the gazillion nut plates on the main tank bay cover. I still need to ream out for the flanges and dimple the cover, but that's not too hard. I traced out and cut out the aux tank bay cover and used a hand brake to bend the edges a bit for better edge contact to the wing. Then drilled all the screw holes for nut plate placement. Tommorow will install the nut plates.
