Brief Description: Recheck for vertcal distance, VS riveting
RecheckVertical distance from top of VS skin to the rear out side of each HS L/R = 62 3/8" Recheck Vertical distance from top of VS skin to the front out siae of each HS L/R =64 3/4"
Removed the VS after checking with the strate edge to make sure it wasn't bending in the vertical aft, used the brackets as all 3 shoud be touching the strate edge, Then checked the 1/4" offset to the left, when both were ok I drilled the holes using thr F-781 to the VS front lower spar, got all i could then clecked all the holes then removed the VS drilled the other top holes. Reivited all with AN -470-4-5 rivetss
