Eagles Nest Web Site
Date: 5-6-2012
Number of Hours: 7.00
Brief Description: Wiring, avionics continue
Little mechanical work was done, only installing the instrument panel. All the rest of the time was spent on wiring and putting in instruments. We had the panel painted, again by Hangar 6, here on OVO. It was a nice job, although I forgot to have the door of the mapbox painted.
All the instruments are in, and all is done under the top deck except running the pitot tube forward. The grips and push-to-talks are in, the elt, and some of the wiring connected. The main things to be done are the ADAHRS and wing connections. We won't install the fuel tank untill the ADAHRS is done.
We have another Eagle's Nest Project, this one in New Mexico. We have 25 going to Oshkosh from the first two projects, 14 from EN-I and 11 from EN-II. See you there!
ELT antenna goes in
Panel filling up
Titanium paint looks good!
