At the end of today I pulled all the pins and staples out of the top leading edge of the Aileron that was glued on yesterday and fitted the bottom ply to that control surface. I then glued and "pin'ed" it in place to dry overnite. This will make up the vast majority of the fitting and glueing of the Aileron for this wing. I have some clean-up and re-enforceing to do on it as done on the others and it will be ready to install in the wing.
Aileron top left Wing bottom leading edge ply fitted and glued
