Brief Description: Nose Gear Bearing & Tube + Top Skin - Forward Fuse
Finally got to do a bit more on the 601 after a long period of other activity. I fitted up the bottom bearing on the firewall - also the Nose Gear Tube ( although it is not yet completed for full installation). I kept moving the Bearing around and didn't want to lose it or damage it so I installed it instead. I also fitted up the top Forward Skin.. again...just because it was made and available. I'll remove it again until the appropriate time to install it but then the fitting will already be done. It was a good day and fun to be back at least for this brief period of work on the airframe.
