Brief Description: Fuselage - front section parts added part 1
Began by marking the longerons for the called for locations (instru pan and upper seat brace) . Set-up the rear spar with the attach plates and marked and cut-out side panel (rear) as called for. Established the across measurements and installed and clecoed in the upper seat back brace.
