Today I drilled out all solid rivet holes in the Left Main Wing Spar to specified size. I then installed 10/24 bolts, washers and wing nuts to secure all parts in proper alignment until I can install solid rivets. I've ordered "cup" rivets sets and expect them in my next Wen.- 6/4. I then fitted, drilled, cleco'ed Left Wing Spar Tip, "L" angles for nose rib #9 and Wing Tip skin attachment.
Drilled out all solid rivet holes to specified size
