Continued work on Spars. Fitted, drilled and cleco'ed Spar Vertical hats & angles to Right Main Wing Spar. Disassembled the Main Center Spar for deburring and primer prep. Primered it and the Main Wing Spar Angles & Hats which I also removed after final drilling, clean & deburing. I next layed-out, cut, bent, flanged the two Wing Tips to add to both Wing Spars when I rivet them together.
All the parts of the Main Center Span Primed - except spacers
All the hats, and angles from the Main Wing Spars primed
