Another Run to Harbor Fgt. The Castors I used yesterday on the Brake are just tool lighweight. Needed bigger/heavier ones. Found them and some other things I needed (or wanted) a counersink and a vinyl headed hammber. Also Stopped at Lowes for a Scoring Knife - Kobalt - Same principle as the Olfa -which I can't find. Tested it on a piece of 5051-H34 .080 I have and it works fine. Also bought another Bansaw Blade to use on Alum. I did not want to sacrifice one of my good wood cutting Bands as I know they load up and dull faster when used on Alum. I found this out when I built my Bus and cut a bunch of it (even with Lube)
