Again is is a combined summary of progress in the cockpit over a couple of days. All of the L's are now in place, the seat "slings" are fitted and in place and the Center Console is fitted and in Place as well as the panel from the center console up to the Instrument Panel. I have not yet drilled the holes that will attach the console cover to the console. I'll need full access to that are to install torque tubes ( that I have not made yet ) and later control cables and other things that are accessed and housed thru this area. If it were not for the clecos sticking up....I could,....I suppose...sit in the Fuse and make airplane noises.....it would be very, very uncomfortable, however, with all those cleco's sticking up.
Seat Belt - lower attachments are alsoin place now as well.
Cockpit - Side L's for add strength
Seat "sling" on Pass Side...also seen is the top Longeron Doubler shown in place
