Brief Description: Fuselage - front side skin - pass
This is a summary of a couple of days efforts. Installed the front side skin on the passenger side and it went well - photo #1. Then moved to the vertical rear spar brace (next in constructon manual) and install those on both sides. I've only installed these with pilot holes as there are more steps to follow on these parts at a later part in the build. I followed that up with the seat back side vertical braces and gussets on each side and drilled them to full size holes.
