Cut out and formed Leading Edge and Tailing Edge Skins for #2 Rudder. Fitted skeleton together, drilled, dis-assembled, deburred, primed and re-assembled then riveted. Layed-out Trailing Edge Skin and marked for Rivet pitch...then drilled. It's ready to insert Skeleton (done) and be riveted together. Leading Edge Skin is ready to fit, drill, deburr, prime and install - as well.
Complete set of parts for #2 Rudder
Skeleton together, primed and ready to insert in skin
Rudder Trailing Edge Skin drilled and ready to receive Skeleton
