Brief Description: Laminated roof supports for tear
Plywood is stronger than just a plain piece of wood, so 2 piece of plywood laminated together is even stronger. These will be used for my roof supports. After gluing I ran them through the planer to get a uniform shape to all the pieces. I space them across the roof all the way back to the galley.
Glued and clamped the roof supports. I made them out of 1.5x3/4 ply laminated together
Cleane up all the glue drip and made all the roof supports uniform in size. Now just to cut to length
Here you can see the roof supports over the galley area
