Brief Description: Cut hole for Moon window and test fit window
Added another lateral support and cut the pieces to frame in the window. Afer epoxy dried I cut a small router with a trim bit to cut the window hole out.
Before window was installed
Hole cut and window temporaily setting in the hole
You can see the window supports and how it will look.
