Brief Description: Added steel supports for roof top carrier for boat
I added a steel frame work I welded up to attach a roof top carrier for carrying my aluminum fishing boat. With a rear hitch to have an extended baggage carrier and the roof top carrier I can take my boat and motor and generator without any problem.
Bracket for attaching roof top boat carrier
1 1/2" square steel tubing has bracket welded on with nuts welded below for mounting roof top carrier.
Steel is bolted to the Tear drop sides. This also makes the sides even more secure.
