I did think about this for a while. I had to do alot of measuring to check out the way the bracket mounts and if and what spacer is needed. I then got on the Groups page and read that there was one in the kit. Iwas nice to find.I was happy in the way I found to clamp the gear legs to the table to drill. I have not mounted yet I need to order the right bolts today. The bolts for the rear mounting of the gear legs to the fuselage were also too long that came in the Wicks kit. I need to place an order today.
Iused a bord and c-clamps to pull leg down on the table
I then mocked up the wheel and brakes to mark the holes
