My Airplane Projects
Date:  2-28-2011
Number of Hours:  1.00
Brief Description:  Hooked up battery charger.
Made up an adapter to hook up battery charger through the 12 volt outlet under the seat. Located an audio jumper wire to hook the right seat headphone outlput to my portable tape machine - for recording test flight parameters.
At the airport hooked up the battery charger and turned on the Dynon. Tested the recorder - seemed to work in low noise environment.
