My Airplane Projects
Date:  11-23-2010
Number of Hours:  7.00
Manual Reference:  36-14
Brief Description:  Continued on wheel pants.
Worked on the right main wheel pant mounting. Trim and fit, trim and fit. Definitely got my excersize getting up and down off the floor. Called the support line at Matco to ask about the big washers that go up against the wheel bearings. Confirmed that they go on the outside only. Removed the left wheel again to double check that side. It was OK.
Did the flox mixtures at the mounting points. Don't really understand the reason for this - just did it. Waiting for the flox to finish curing overnight. Tried to remove the nose leg fairing where it was RTV'ed to the waxed strut. It was stuck solid. Finally got it off and removed all the RTV, and repeated the process, this time with a piece of plastic taped to the strut.
Reinstalled the nose pant and tested full range of motion. Marked for a slight trimming needed to one side of fairing at bottom.
Nose - waiting for RTV to cure.
Epoxy pad at main mount point.
