My Airplane Projects
Date:  10-21-2010
Number of Hours:  2.50
Manual Reference:  33-03
Brief Description:  Finished data cable, installed tunnel cover.
Went to Albany for my FAA physical this morning. Now the Arrow annual and my annual are on the same schedule.
This afternoon I finished the data cable hookup. Tested it with a serial extension cable and the serial to USB converter. Was able to communicate just fine between the laptop and the Dynon. See photo 1 for cable routing.
Pinouts as follows:
Dynon DB25 Pin 9 - PC DB9 Pin 5 WHT/BLK
Dynon DB25 Pin 10 - PC DB9 Pin 2 WHT/ORG
Dynon DB25 Pin 22 - PC DB9 Pin 3 WHT/YEL
Got inside the cockpit and labeled the "spare" wires in the tunnel. Then installed the mounting plates and the tunnel cover.
Data wire from DB25 to DB9.
Tunnel covered.
Tunnel covered.
