My Airplane Projects
Date:  10-1-2010
Number of Hours:  6.00
Manual Reference:  12-10
Brief Description:  Finished tail cone fitting.
Worked all afternoon on getting a good fit on the tailcone. Had the stabilator on and off several times. It gets easier after you learn a few tricks. Ended with a good fit and specified clearances. Took about 1/8" off the metal on the bottom of the stabilator. Installed the nutplates and riveted in place. Test inserted all the mounting screws.
Cone test fitted.
Cone test fitted.
Nutplates drilled and clecoed.
