My Airplane Projects
Date:  10-14-2010
Number of Hours:  4.00
Manual Reference:  32-13
Brief Description:  Hooked up tail control surfaces, then disassembled
This morning I sorted out all the tools I brought home from the airport (the Arrow is finally back together.) Cleaned up the shop and put everything back in its place. Then made the links for the rudder cables and test fit. The rudder hits the stops in both directions before the pedal hits the firewall.
Hooked up the stabilator cables for a test fit but did not tension. Then removed all the tail surfaces and bagged the associated hardware. Moved the fuselage out into the garage and moved the fiberglass parts into the shop for more finish work.
Rudder hookups - forward.
Rudder hookups - aft.
Ready to work on fiberglass - again.
