Brief Description: Installed corner skins with Nick & Lauren.
Removed corner skins to smooth the exposed edges. Had help from Lauren and Nick from Ohio re-installing them. Both turned out to be good cleco and rivet installers. Later prepped the fuselage corner skins and installed. Laid the bottom skin on the assembly to check the fit - perfect! Worked for a while on deburring the botton skin stiffeners and doublers. Thanks for the help, Nick and Lauren!
