Experimented with best method(s) to get a smooth finish on the fiberglass parts. Ended up dry sanding with 220 paper, then following up with a wet sand of 320 paper. At first tried just wet sanding with 600, and that makes a real smooth finish but takes too long on the big parts.
Mixed a small batch of runny micro balloons and used that to fill the last of the pin holes.
