My Airplane Projects
Date:  3-31-2016
Number of Hours:  0.00
Brief Description:  Air box, carbs, misc.
Reviewed with Bill: Gear boxes, carb air box, carburetor. Decided on method to install bearing kit in air box (tubing and taper pins), cut tubing, bead blasted air box. Bill removed drain plug from carb bowl. Ordered reamer for inside dimension of rocker bushings. $$$.
