My Airplane Projects
C120
Starter, antenna, brake leak, other...
Installed blade antenna on belly.
Put oil back in tank, checked for leaks at drain plug.
Installed starter, shortened and reinstalled starter wiring.
Adjusted carb heat control linkage to avoid rubbing on oil tank.
Looked for brake fluid leak left aide, tightened small screw where I think it was coming out.
Installed plugs in two extra firewall openings (with Sam.)
Installed new tach cable.
Received message from Rich Klein, he has a KT76A.
Starter mounted and rewired.
Fleet Model 16 Home
C120 Home
1412
Elevators
Exterior Finish
Flight Tests
311
Horizontal Stab.
Lighting
Modifications
Preparation
Skiis
Wheels & Brakes
180
RV-12 Home
