My Airplane Projects
Date:  11-14-2015
Number of Hours:  0.00
Brief Description:  Disassembly of items in gear box area.
Bill removed rivets top of right side aft door post so as to remove buckle in skin in that area. He also built tail support and measured twist in fuselage. Jeanne and I worked on removing all wires, cables, brake and fuel lines etc. that feed through the gear box area. Took extensive pictures before removing each item. They are on iPad and N drive.
