My Airplane Projects
Date:  2-25-2012
Brief Description:  Worked on corrosion on right wing.
Drilled out and removed the smaller panel with the corrosion that resulted from the strap. This panel will have to be replaced for sure. But I am hopeful that the large panel may be able to be saved.. I sanded out the corrosion, which appears to not be very deep. It will be Bill's call.
Trailing edge corrosion.
Wing panel corrosion sanded.
