Christopher's Web Site
Date:  1-9-2017
Number of Hours:  3.00
Brief Description:  Install Tail Rotor
I looked everywhere for any instructions about installing the tail rotor, but I never did find anything. I looked back at a number of photos of other ships over the years and tried to account for everything I needed to from the success of others. There are 4 bolts that hold the tail rotor to the frame from the bottom, and there are 2 more bolts that hold the gearbox down to the frame with an arch piece. Those 2 holes needed to be drilled as well. It was a little bit of a pain in the butt just because of the angle marking them, but it worked out fine.
This is another one of those significant components that make a huge impact to the look of the helicopter. The tail rotor is an obvious part of the ship and can’t be confused as anything else. I will be adding stripes to the titanium blades, but I figured it would be easier to apply them once it was bolted in place. The rotor looks and feels very smooth.
Tail rotor installed!
Top arch mount
Top arch mount
Underside tail mounting bolts
