Glued up the first wing rib! Spend an hour or two in the shop cutting a few gussets, marking rear rib ply pieces for rough trimming and cut a set of spruce sticks to put in the jig. A 1/4 ounce of T-88 mix was more than enough to glue up the spruce with gussets. There was enough left to have glued gussets on both sides of the rib, so the plan will be to glue up the back side gussets of the previous rib when assembling a new rib.
