Brief Description: Install Gascolator and final fuel line fab work
Installed gascolator. Fabricated straight piece of aluminum stock. Installed with clamps. very sturdy. Will work perfect. Only the drain should extend beyond the fabric which is what I wanted. Remaining fuel lines secured with adel clamps. still need to fab final line from gascolator to fire wall and from selector to gascolator. Waiting on 90 degree fitting to install in gascolator. will then run 90 degrees and straight to bottom left of fire wall.
