Brief Description: Coutersunk Main spar for wing skin rivets
I countersunk the leading most hole on the main spar at each of the ribs behind the fuel tank. Iplan to put a rivet through the spar to the rib flange as these holes are covered by the fuel tank. I then strated countersinking the spar to accept the dimpled wingskins as per the plans
