Brief Description: L T/S: Scarfing corners on Top Skins
I removed the plastic as per the instructions for the area to be scarfed on the Wing Top skins. I taped a tin dowel to my Vixen file to ensure a constant, tiny angle on the File. I then removed what I deemed to be sufficient material and test fitted. Looks fine - might be a little on the thin side right at the very edge of the corner - time will tell
plastice removed, taped and clamped to the work-becn
Small dowel taped to vixen file
Test fit to chack the overlap of the scarfed area - looks great!
